• If you have bought, sold or gained information from our Classifieds, please donate to Wild Dog Adventure Riding and give back.
    You can become a Supporting Member or just click here to donate.
KLR parts available
Titanic
Gauteng
BMW F800GS
I recently bought a KLR 650 (fugly 2006)  for parts, so I have the following plus a bit left and need to get rid of it.
Not everything is listed, so If you don't see it, you are welcome to ask for it, especially the smaller bits.
I'll add photo's on request.
PM me for further details.
Foot brake lever
tripple clamps top HOLDER-FORK UPPER sold as a set
Tripple clamps bottom HOLDER-FORK UNDER sold as a set
tail light
side stand (needs attention) needs attention
indicator each 2 rear and 1 front available
front hub complete, no damage
front hub meter gear assy
front axle
front master cylinder (complete incl lever) needs new seals
handle bar (standard)
COVER-HANDLE black left pig ear
swingarm
swingarm adjuster chain outter
swingarm adjuster chain inner
LENS-COMP,HEAD LAMP
BODY-COMP-HEAD LAMP (bracket)
Switch assy (1 key, ignition and tank lock) 1 key, no helmet lock
Meter cover case (bottome white piece)
Meter TACHOMETER,X1000R/MIN
METER,TEMP
Muffler header front
Muffler exhaust back (standard)
HOLDER-BRAKE,REAR CALIPER
rear calliper complete needs new seals
rear axle
COUPLING-ASSY,REAR HUB (sprocket carrier)
rear footrest holder bracket left
rear footrest holder bracket right
front footrest bracket holder left
front footrest bracket holder right
Wheel spacer rear right 42036-1206
wheel collar COLLAR,REAR AXLE,L=17
92143-1062
COLLAR,REAR AXLE,L=30 92143-1061
Brake pedal shaft brake 43004-1120
SPRING,BRAKE PEDAL RETURN 92144-1082
air cleaner holder 13091-1473
air cleaner bolt 92002-1904
Rear wheel sold
Fairing stay brack sold
Engine not available
speedometer not available
plastics not available
airbox not available
radiator not available
front wheel damaged not available
rear master cylinder bracket not available
rear shock not available
right hand switches not available
left hand switches not available
mirrors not available
water reservoir not available
rectifier not available
tank not available
mudguard not available
shrouds not available
bracket around reservoir for shroud not available
cables not available
screen not available
carburetor not available
seat not available
