AndyF
ON PROMOTION – 10 Watt LED Spot and Mounting Bracket Set -
This awesome little 10 Watt LED spot will improve your visibility to others as well as light your way in the dark !!!! Only 55 mm in diameter !!!! Does not include a loom - Carries a one year warranty
The spotlight mounting brackets will fit tube diameters from 25 mm to 32 mm – made from aluminium and coated black – they are supplied as a pair
Yours for just R 900 for both collected or R 999 to a Postnet closest to you !
While stocks last – reserve yours by PM please !
