ALL PRICES ARE NEGOTIABLE
Front hub no spokes or discs R500
complete sub assembly R6000 Barrel is repairable
subframe R1500
Complete rear rim R2000 (not sure about the tire) (Sold)
Swing arm plus the final drive assembly R3000
Complete standard exhaust system R1200
Tail Light Complete with number plate holder R600
Front Seat R750
Top Yoke R1500
Complete Harness R1000
Complete Brake Lines R 450
Clutch master and Slave cylinder R 800
Rear Brake switch R 50
Front and Rear Calipers R1500
Rear Brake Master Cylinder and Reservoir R 500
Front and Rear ABS Sensors R 200 (each)
Rear Brake Lever R 300
Complete Rear Shock R 1500 (sold)
Rear Brake Master Cylinder Protector (aluminium piece that mounds to foot rest) R 100(spld)
Complete Pillion Foot Rest (brackets incl.) R 1000
Complete set Front Foot Rests R 500
Swing Arm Brake Line Protectors + Final Drive Protector R 100 (each)(sold)
Complete ABS Unit R 2000(sold)
Sub frame Inner Plastic (under tail) R 750
Complete Throttle Body R 1500
Silver Plastic Behind Pillion Seat R 500(sold)
Bash Plate (needs welding) R 400
Radiator Pipes R 100 (each)
Rectifier R 750
Coil Packs R 200 (each)
Tappet Cover R 500
Radiator Reservoir Tank R 150
Main stand and Side Stand (Sensor and Springs incl) R 1000 (Main stand Sold)
Throttle Cables R 150
Timing Chain Tensioner R 350
Complete Air box R 800
Electrical Relays R 50 (each)
Lamda Sensor R 400 (each)
Screws R 200 For The Lot (Reserved with the disc and pads)
Cams R 750 (each)
You can contact me on 0784588221 if i dont answer just leave a voice mail ill get back to you. Based in Pretoria I will post fotos on request.
Sean
subframe R1500
Front Seat R750
Top Yoke R1500
Rectifier R 750
Tappet Cover R 500
Cams R 750 (each)
Sean
