Hi Guys,
My GSA's high beam is lighting up the sky when I switch it on. I tried adjusting it with the screw adjuster at the back of the headlight casing, but it does not have any effect. I think the low beam is also higher than usual.
I removed the globe to try and see if the reflector screen is not loose, but it seems pretty sturdy to me.
Any ideas what I should do to fix it?
