zebra
Bachelor Dog
- Jun 23, 2008
- 14,388
- 992
- BMW (all models)
We get a lot of newish products into stock, but do not always get the time to update the website, or announce them here, so here goes:
FRIDAY: DAY 1:
PROP-IT Bike Prop: very useful for trail-side repairs, whether using it under the bash plate, whilst repairing a front tube/tire, etc, or also using it under the rear swing-arm...
the pic shows DOUBLE adjustable, which is redundant, so we've made it SINGLE adjustable.
LENGTH closed: 36cm
LENGTH extended (MAXIMUM 60cm)
MATERIAL: Aluminium shaft
END CAPS: RUBBER (so non-slip)
Price: R199 incl VAT, excl postage.
Cheers
Chris & Team
MONDAY: DAY 2:
next new product, this one to save space/weight/and to fit in a small space...!
Hex Drive
17mm Hex drive, with 32mm, 27mm, 24mm, 22mm, 21mm, 19mm Spanners
R489 for the 7-piece set.
you then only carry one 17mm spanner to have 7 spanners!
(we can supply the 17mm spanner if so needed, we supply the combination tire spoon/spanner, additional R249)
TUESDAY: DAY 3:
A C-O-M-P-A-C-T compressor, that still gets the job done, Moto-Pressor, designed in Australia, a Chinese-made, quality product, with the focus on compactness, and strength/reliability.
ULTRA compact, this stripped down pocket pump weighs in at only 570g and fits in the palm of your hand. What is lacks in looks, it makes up for in performance AND functionality - which is what you really need when you're stranded in the middle of nowhere.
R699 incl.
what's NEW, is how it is powered: it uses a permanent 'pigtail', wired on to the battery, so power is always avaialble, especially since MOST ALL compressors will not work with the BMW CAN-BUS system, since they are most always over 5 amp, and the BMW Hella plug is limited to 5 amps...
the benefit of using a SAE plug, is that the plug is one of the best in terms of making a good, cannot-be-accidentally-dislodged, connection!
The plug is also incredibly slim, ideal for threading it through a small opening, etc.
MotoPressor has a 63cm long inflator hose, with a hands-free, lock-down delivery valve that fits all bikes. A long 2.65m SAE fused power cord comes with two adaptors: a direct connect for your battery and alligator clips, both with SAE connectors. Included in the kit is a sports needle for blowing up footballs and a couple of nozzles for inflating airbeds etc. All this packs small into the included heavy duty neoprene pouch.
MotoPressor will pump the front tyre of your motorcycle from flat to around 32 psi and the rear to around 28psi in two (2) minutes (Tests run on a BMW R1200GS). MotoPressor is capable of pumping over 100 psi!
Video - setting the bead: https://www.rockycreekdesigns.com/tyre-accessories/motopressor-tyre-pump.html
Cheers
Chris & Team
WEDNESDAY: DAY 4:
JETPUMP - a unique - refillable - CO2 canister for re-inflating tires!
Jetpump is a uniquely designed South African product that was specifically designed to provide an effortless way of in- or re-inflating just about anything, especially motorbike and vehicle tires. Obviously, it's resealable, so only use as much air as you need, then turn the tap off!
Supplied with a neoprene pouch which serves TWO purposes:
it keeps your fingers from freezing during 'actuation'!
it keeps the bottle in a secure pouch for the rigours of off-road riding.
R550.
It's refillable - any paintball shop can refill it, at usually just R20 per refill, yet this 4OZ/120g canister will fill up MULTIPLE motorcycle tires, from flat!
(canister is provided empty, just so you know!)
Bear in mind the LARGE CO2 'bombs' most of us use are just 16 grams, so 120 grams is 10x what the the regular bombs cost...
Cheers
Chris & Team
FRIDAY: DAY 1:
LENGTH closed: 36cm
Cheers
Chris & Team
MONDAY: DAY 2:
Hex Drive
TUESDAY: DAY 3:
R699 incl.
Cheers
Chris & Team
WEDNESDAY: DAY 4:
R550.
Cheers
Chris & Team
