frontier
Advise needed.
When the engine is not running and the bike stationary, selection is a breece from 1 to neutral to 2nd etc.With the engine running gear selection from neutral with usual thump into 1st and then will not go back into neutral?It goes from 1st into 2nd .
During riding gear selection normal but would not go into neutral.I will switch the engine off and then it will go into neutral ?I checked all the adjustments as per the manual and all is normal
What can be the problem?
