Raka
My brake light recently fused. When I replaced the globe , I saw the brake light keeps burning. It switches off if I wiggle the microswitch at the front brake, but once you pull the brake it stays on again.
Heres the kicker, I can actually here the switch go on and off(as in click click) , but the light stays on, until I wiggle the connection a bit. When it does go off, more wiggling make it light up again.
Its obviously not ideal so heres the question: Can you set the switch or must it be replaced ?
