Galatrix
According to the pro's the sag should be 3" when i sit on my bike.
I measured the from rear axle nut up to the grab bars the distance is 59cm
On preload setting 1:
it is 47.0cm
On preload setting 2:
It is 48.0cm
On preload setting 3:
it is 49.0cm
On preload setting 4:
it is 50.0cm
On preload setting 5:
It is 51cm
So according to the 3" sag which is 8.19cm Setting 5 is the correct one, but i can't see that it is right as i only why 97kg.
it is 47.0cm
It is 48.0cm
it is 49.0cm
it is 50.0cm
It is 51cm
