Gryshond
The point of all posts in this section is try and get an overall view of the characteristics (good or bad) of each tyre listed in order to help people select the tyre that best suites their needs.
The more people who vote the more those characteristics should emerge.
BUT THAT WILL ONLY OCCUR IF YOU STICK TO THE FOLLOWING GUIDELINES:
1) Only select "Good" or "Bad" for any particular aspect if your experience was either much better (or worse) than you would expect from a run-of-the-mill tyre. If the tyre was merely OK, or if you don't really know what to say, please select nothing in that case.
2) Please only vote if you have actually used the tyre in question. Even then only vote for characteristics of the tyre that you are familiar with (eg if you never venture into mud, don't vote on that aspect). Please don't just replicate what others have told you about the tyre, or what the marketing blurb says. We want to know about your actual experience with the tyre.
3) If the tyre sucks at something please say so! Its actually more important to warn about problems you experienced than just singing the tyre's praises.
3) Vendors of the tyre should NOT vote.
4) Please dont try and skew the results to try and get your favourite tyre to "win". :biggrin:
5) Dont vote straight after you buy a tyre. You are still in the "honeymoon period" at that stage - rather wait a bit until after you have had your first fight and hopefully have made up afterwards :biggrin:
6) Feel free to add your comments about the tyre after voting but please stick to the topic.
7) Please note that there are separate threads for Front and Back tyres of the same type.
