- Jul 27, 2010
- 5,499
- 670
- Blouberg, Cape Town
- KTM 890 Adventure R
Now in Table View!
See and be seen! Fit the most affordable 1000 Lumen spotlights on any bike from 125cc to 1600cc. Vastly improve visibility by night, and be seen by motorists during daytime.
This Mini Motorcycle Spotlight is almost too small to be this bright. The lens on the 1000 lumen Motorcycle Spotlight allows it to extend your visible range significantly at night. It uses 10W of power but matches a 55W halogen light in output.
Beam pattern has a very sharp hotspot but wide flood element. During day time it will make your motorcycle very visible.
Extremely tough and rugged. Aluminium die cast body with thick polycarbonate lens.
Installation is easy. Bolt on to your bike and run directly off the “brights” pos and neg wires in the headlight.
Specifications:
• 1 High Intensity LED per spotlight
• LED Power: 1 x 10 W (CREE XM-L U2)
• Extra-long Lifetime
• Sturdy Diecast Aluminum Housing
• PMMA Lens
• Waterproof Rate: IP 67
• Color Temperature: 6000K
• Operating Voltage: 10-30V
• Current Draw: 1A@12V,0.5A@24V
Additional Information
Weight 0.3kg
Dimensions 9x9x7cm
Brightness: 1000 Lumen
Price:
R375 per light (R750 per pair)
Specifications:
• PMMA Lens
Weight 0.3kg
Dimensions 9x9x7cm
Price:
