quick KLR rear suspension question
Wabbit16
Port Elizabeth
AJS (all models)
I'm busy installing my rear shock again, but I have noticed a slight (about 1 - 1.5mm) sideways play in the shock mounting where the bottom 'forks' of the shock mount onto the linkage unit. With the bolt and nut installed it has some play, almost as if the two 'forks' of the shock are too wide. Is this normal?
