REPLACEMENT PARTS LIST
Grotex
Hermanus
BMW R1200GS
This is a compilation of info gathered from the forums
I will maintain this
BUT!!!!!!
I will need the help of all on this forum to varify the data and
to keep the data up to date
Thus all comments,suggestions and corrections will be appreciated
and will be added to the original list that could be a separate sticky thread ??
                        ALTERNITIVE PARTS NUMBERS
Oilfilter GUD   Z152 Z85 ??
K&N KN-163
Fram PH6063 PH3614 PH4875
NAPA   1348
AC Delco PF-53
Bosch 3330
Midas Z188 (BMW car replacement)
Spark plug Bosch   F7LDCR  !!! FR7DC (7555 FR6LDC
"Bosch FR7DPX (4201) Platinum factory gapped at .44"""
"Bosch FR7DP-4 (4417) Platinum+4 preset gap, never tested in motorcycle"
NGK BKR7EKC-N BCPR7ET BCR6E1X-11
Champion RC9YC RC7YC RC8YCC RC6PYP
Brisk DOR14LGS
Denso K22TMR11 3249 VK22 Iridium
Autolite 3923
"Denso VK22 Iridium centre, Platinum ground Preset"
NGK PFR7Q Special ground Preset
Denso IK22 Iridium centre electrode Preset
Champion RC6PYP Double platinum Preset
NGK PFR7B Double platinum Preset
"NGK BKR7EVX Platinum centre, tapered ground Preset"
"Denso K22PR-ZU Platinum centre, tapered ground Preset"
Champion RC7BYC 2 ground electrodes Preset
"NGK BKR7EKC 2 ground electrodes, non SSD Preset"
NGK BKR7E Standard Preset
Champion RC6YC Standard Preset
Champion RC7YC Standard Preset
Alternator Belt NAPA 40233
CONTI 4K611
GOODYEAR 4040245
Midas 4pk610
Dayco 12.31-1 342 087
Fuel line connector Rectus T21 Male and Female Pipe coupler for 8mm pipe
oil pressure switch/sensor "Midas 12611277642....same switch used in the BMW 318 E30....M12 x 1,5mm pitch"
Fuel Filter BMW 16.14-2 325 859 13.14-1 461 265
Mahle/knecht KL145 (original)
Deutsch FF424
GUD   Z85
Air Filter K&N BM-0400 Product Style: Round Air Filter
Height: 3.375 in (86 mm)
Inside Diameter: 3 in (76 mm)
Outside Diameter: 4.375 in (111 mm)
Top Style: Open
Uni Filters NU-7305
Mahle/knecht LX578
Mann/Hummel C1552 (original)
Battery "Odyssey PC-680, 180(L) x 170(H) x 75(W"
Yuasa YB18L-A
Varta 51 913
Brake pads EBC FA335 (F) EBC FA246
EBC FA363 R
BREMBO C 34 21 7 660 281
FERODO 2050P (BREMBO) FRONT
2125P NON ABS
2124P SOME 1150
2039P REAR
Hall sensor Honeywell 2av54
O2 sensor Bosch 13474
Bearings
Front wheel 1 x 3205 2RS RC3
1 x 6204 C3
Rear wheel big Midas 33.12-1 242 210: 85x120x18 (C3)
Rear wheel small Midas 33.12-1 451 188: 25 x 52 x 16.25(C3)
front crankshaft seal (breather) 11.11-1 341 849: 40 x 62 x 7
front crankshaft seal (under hall sensor) 11.11-1 340 773: 30 x 42 x 7
gearbox
input shaft seal (1100) 23.12-1 340 331: 22 x 36 x 6
output shaft seal (all) 23.12-1 340 324: 25 x 40 x 6
lever shaft seal (all) 23.12-1 340 322: 12 x 22 x 5
final drive
input shaft seal (the infamous) 33.11-1 451 185: 35 x 47 x 7
output shaft seal (wheel side) 33.12-1 241 619: 85 x 110 x 10
bellows steel clamp (big) 33.17-2 452 584 has 131 mm diameter
bellows steel clamp (small) 33.17-1 458 197 has 90 mm diameter
final drive pivot bearing 33.17-2 311 091: 10 x 32 x 16
needle bearing from input shaft (small) 33.12-1 236 996: 15 x 30 x 18
big bearing from output shaft (wheel side) 33.12-1 242 210: 85 x 120 x 18
o ring from neutral switch (1100) 23.31-1 341 754: 28 x 2
triple tree bearing 31.42-2 314 725: 20 x 47x 20.6
hose clamp (Oetiker) for fuel filter 13.31-1 462 928 has 13 mm diameter
BMW part number Use Size & type Bearing number
OD x ID x Length
07 11 9 985 070 "Steering head bearing, /5 through F650 Dakar" 52x28x16 SKF 320/28 X/Q
FAG 32028
07 11 9 985 005 "'55 through '84 tapered wheel bearings, all swingarms up to 1/81" 40x17x13.25 tapered roller
SKF 30203
36 31 2 312 520 "Front wheel, right side R11 3-spoke and R11xxGS" 47x20x14 grooved ball SKF 6204
-2RS1
36 31 2 310 972 "Front wheel, R11 3-spoke left, K 3-spoke right (radial only), R11xxGS left" 52x25x20.6 grooved
ball INA 3205-2RS F0712
33 12 1 468 899 "Rear drive ring gear large bearing, R80 through R1150" 85x120x18 grooved ball 61917/C3
33 12 1 451 188 "Rear drive ring gear small bearing, K100 through R1150" 52x25x16.25 tapered roller SKF 30205
J2/Q 07 043
33 12 2 310 925 "Rear drive pinion large bearing, K100 through R1150" 62x25x25.4 roller & ball F-213832
F-229445
33 12 1 236 995 "Rear drive pinion small bearing, mono/para through R1150" 30x15x18 needle sleeve
F-90445
33 17 2 311 091 "Paralever pivot bearing, R80GS through R1150" 32x10x17 FAG 10-6465A
33 17 2 311 729 Swingarm bearing Oilhead and K12 tapered roller bearing
Fuel Pump BMW 318i 228-220-004-002 C
Midas JJDB4M
Bosch #0 580 314 068
