Small super bright and light weight headlamps
Extremelights
Stellenbosch
Suzuki DR650
We have added two impressively small headlamps to our range. These headlamps both have a place in any seasoned adventure seeking outdoor spirit backpack.
The XPh3A has in incredible focused hotspot with a wide flood element. Make the most of the 160 lumens of light. If you find yourself frequently having to look down a trail and you need a backup light that will match your primary headlamp this is it. The waterproofing, red LED’s and AAA battery size is a welcome bonus. For R299 you will be hard pressed to find anything matching this light performance.
Get them here
HP1A  https://www.extremelights.co.za/product/rayfall-hp1a-headlamp/
XPh3A  https://www.extremelights.co.za/product/hp3a-headlamp/
The AA battery size is by far the most easily to get. In most cases you get 4 of them and that makes the Rayfal HP1A ideal. It uses one AA battery and light up the night with ease. It is also waterproof to 1 meter and is equipped with a set of RED leds for when you need it. It almost produce the same amount of light as the XPh3A but with the much wider and even beam pattern it is ideal for when you need to light up your immediate area well. At R195 inc 1 Duracell battery it will not break the bank.
