• If you have bought, sold or gained information from our Classifieds, please donate to Wild Dog Adventure Riding and give back.
    You can become a Supporting Member or just click here to donate.
Spots - Street LED Spotlight 1000 Lumen
Jacobsroodt
Blouberg, Cape Town
KTM 890 Adventure R
Classy, sturdy spotlights for super bikes and adventure bikes alike, and anything in between. Physically smaller and lighter than the average spotlight, but still delivering 950-1080 Lumen, it can be used as daytime running lights and spotlights.
Instead of throwing a shaft beam, light is distributed evenly with a 25° view angle, making it ideal as DRLs where being visible from the side is important. It evenly lights up the road ahead.
Mounting points are integrated in the aluminum casing, making them sturdy for bikes with hard suspensions and the bumps adventure bikes throw at them. Stainless steel mounting brackets.
Specifications:
Input voltage: 10~30V DC
Constant Current: 900mA@12V,400mA@24V
Power consumption: 10W
Luminous Flux:        950~1080 Lumen
LED Source: Cree XML-T6  LED Chip
Certification: CE,RoHS,FCC,ISO9001,E50
Housing construction: Aluminum
Lens:        Virtually Unbreakable PMMA Lens
Mount:        Stainless Steel mounting bracket, 40cm chord
CCT:         6,000~7,000K
Beam Pattern: Spot Beam (25deg)
IP rating:        IP68
Dimensions (mm):        51.2(D)* 61.0(W)* 66.7(H)
Working temperature: -45℃~105℃
Working humidity:        10%~98%
Light source life span: >50,000Hrs
It’s a tough little light, shock proof, corrosion resistant and uses a "virtually unbreakable" PMMA lens.
Comes with a stainless steel bracket for mounting to your motorbike.
Price: R480 per light.
Latest posts
