camouflage762
From R90.00
Hyper Flame Gas Torch ZT50 with Refill ***New Army Pattern***
Includes 18ml Gas Refill
Does NOT require special adaptors to Refill the Flame Gas Torch
At least 10-20 Minutes burn time per Refill
Flame length between 4-6cm Depending on Setting
Base provided for to allow the Flame Torch to remain upright
Flame Gas Torch Diameter: 28mm
Height: 105mm
Comfortably fits in a Pocket or Mag Pouch
Reliable Piezo ignition
Actuator can be set in Locked position to prevent accidental switching on OR for a long continuous burn
Use to Reliably Light Fires, Pipes, Cigars, Gas Stoves and also use to Solder with or boil a cup of water.
To order, contact us on 011-477-7031 or email us on [email protected]
MAG
#TacQM
Height: 105mm
MAG
#TacQM
