• If you have bought, sold or gained information from our Classifieds, please donate to Wild Dog Adventure Riding and give back.
    You can become a Supporting Member or just click here to donate.
2WATT SOLAR BRIEFCASE - PERFECT FOR BIKING
XRV750
Bergvliet
Honda XRV 750 Africa Twin
12V 2W Solar Briefcase
    * Designed to charge 12V lead-acid batteries with no additional running costs
    * Portable solar generator built into a protective briefcase making it ideal for camping, caravanning or marine use
    * This charger requires only daylight to work, charges even if the weather is overcast or dull
    * Ideal for cars that will be left standing for long periods of time, as well as for maintaining batteries in caravans and boats
    * Built-in blocking diode prevents reverse charging from the battery to solar panel
    * Flashing charge indicator
    * Interchangeable connectors: cigarette lighter plug and crocodile clips
    * Durable ABS outer casing
    * Integrated adjustable angle support
    * Easy storage
Designed to trickle charge 12V lead acid batteries with no additional running costs. Ideal for cars that will be left standing for long periods, as well as for maintaining batteries in caravans and boats. The built-in blocking diode prevents reverse charging from the battery to the solar panel at night. The briefcase comes complete with an adjustable angle support that allows you to position the solar panels in prime sunlight. The solar panel is an amorphous receptor and is ideally suited to the northern European climate to enable the optimum use of daylight hours. It can even operate behind glass.
Still in box, never used.
Bought from Goose for R420.
Yours for R350 excluding postage.
