- Aug 10, 2007
- 8,365
- 154
- BMW R1200GS Adventure
One available only!
BRAND NEW - STILL IN PACKAGING and unused!
The Solar Panel is 2.4W and ideal to use for those remote bike trips.
Waterproof and rugged casing - these are normally used on the vehicles transported on bulk vehicle-carrier ships, stuck in their windscreens and plugged into the cigarette lighter socket to trickle charge the battery over long voyages.
Description:
* Keep your battery topped up with solar power, even if the weather is overcast or dull
* Interchangeable connectors: cigarette lighter plug and crocodile clips
* Durable ABS outer casing
* Built-in diode prevents reverse charging
* Suction cups for easy mounting
* Ideal for cars, caravans, boats etc.
Designed to trickle charge 12V lead acid batteries with no additional running costs. Ideal for cars that will be left standing for long periods, as well as for maintaining batteries in caravans and boats. The built-in blocking diode prevents reverse charging from the battery to the solar panel at night.
Technical specifications:
Peak output power: 2.4W
Voltage (@max. power): 17.5V
Current (@max. power): 137mA
Open circuit voltage: 21V
Short circuit current: 225mA
Tested under standard condition: AM1.5, 100mW/100cm² @25°
Cigarette lighter plug fuse rating: 0.5A
Cable length: 2.7m (9ft)
Dimensions: 350(l) x 215(w) x 14(d)
Weight: 1150g
R 385.00 to the first respondent!!!
Collect from me..... or add R50 for postage & packaging and I'll send it to you via Parcel Post! :thumleft:
PLEASE NOTE - 1 unit only!!!
Description:
Weight: 1150g
