70W Night Raider LED Spot Light
Extremelights
Stellenbosch
Suzuki DR650
A LED Spot Light that is truly a SPOT light! With a narrow beam pattern of ONLY 7 degrees, the 70W Night Raiders have the narrowest beam pattern and furthest reach of all our off road lights. It boasts a 400m usable beam distance! This is unequalled in he world of LED Spot Light. It is Larger in size than a work light, it also has a macho appearance!
To read more click https://www.extremelights.co.za/product/70w-night-raider-led-spot-light/
Individual Deep Reflectors with Clear Lens for Maximum Beam Distance
Super Narrow 7 Degree Beam Angle. See Beam Angles for full details
6 amps at 12V
Runs on 10V to 30V
High Power CREE XM-L LEDs
Actual Lumen 6 300 (Theoretical Max of 7 000)
Sealed Deutsch Connectors
Over Sized heavy duty mounting bracket
IP67 Certified (1 meter water depth for 30min)
Electronically protected against RFI/EMC interference
CE, Rohs Compliant
12 month warranty
165 mm light unit diameter, 200mm high when mounted
Supplied WITHOUT a relay wiring kit.
