Hi all,
I love the concept of the front abs working and the rear switched off as on the 1190.
Is this possible to do on the 990?
1: put a switch in line with the rear wheel sensor. Will this also render the front inoperable?
2: bypass the abs pump on the rear wheel, connect the brake and wheel cylinder directly with maybe the pipe of an S model and block of the pump where it goes to the back wheel.
I think option 2 might work, but if it does the abs on the rear wheel is permanently off.
Any ideas will be appreciated
