Bleeding brakes
sidetrack
Grumpy Mutt
I guess old news for the pro’s but I just discovered the quickest way yet to fill a dry system. Fill reservoir, pump lever and the bleed the master cylinder first at the banjo bolt. When brake fluid appears do the same at the bottom banjo(s). From there bleed normally at brake nipples. 15 minutes max :D Have not tried reverse bleeding yet.
