Brake disc touching caliper
Louis Photo
Honda XRV 750 Africa Twin
Last week I took the wheels off my 750 AT to replace the tyres. After refitting the front wheel, the right brake disc rubs lightly against the outside of the caliper housing, on the the left the disc runs straight through the centre of the caliper. I removed the wheel once again, cleaned and re-greased everything and made sure everything is fitted correctly. One of the little mounting pistons on the caliper was a bit dry so I gave it a little grease. Anyway, I refitted the wheel and the problem is still there, Any thoughts would be welcomed, thanks.
