Falcon
- Nov 20, 2009
- 476
- 0
- Suzuki DR650
Hey there can anyone help me with starting my DR650 what am I doing wrong if anything??
The Problem! :BangHead:
When starting, especially if you only just did a short run, if you miss that the 1st take/fire as you press the happy button, on trying again the motor just turns.
If you keep trying (3 to 4 times) the battery karks out and there you sit!
Trial and error solutions (Actually Symptom management - Need a cure besides ccasion14: )
•If at 1st you don't succeed chill and wait 5 mins then try again, before you suck the battery dry, works most of the time.
•The back wheel just locks up if you try to runstart (1st 3 gears)
•Use the car to jumpstart the bike - not an option away from home
It wasn't always doing this..
My delightful hubby has ...
•Cleaned the airfilter
•Sprayed about a 1/4 tin of Carb cleaner through the carb
•Tricklecharged the battery
•Checked the plug it looks fine
Any wisdom and old dog knowledge would be great
