Latie
Hi I need some advice: ???
A friend of mine have trouble with his Yamaha 350 warrior [ Ja I know it is a quad and not a real bike].
No spark.
The following was tested
Kill switch, ignition switch,clutch switch
All grounds and connectors checked and cleaned
No broken wires
In the manual it give the values , and the following check out of spec
Pickup coil, value must be 209 ohm, checked it and value is 520 ohm but now my problem in the beginning of the manual it gives the value in the 500 range, and on the troubleshooting guide it gives the value in the mid 200.
As you know just changing parts with new ones will get expensive, so what value must I work on, is there place in WC that can test the Stator / Pickup and maybe CDI
No spark.
No broken wires
