Solstice LED Spotlights (test pictures added)
Katundu
Gauteng, Alberton
KTM 950 Adventure
Katundu now supplies LED Spotlights
New Price R1150 Each (old Price R1200 each)
Equipped with brand new 10 watt LED technology,each 10 watt Solo produces 900 lumens, making them the brightest LED off road lights on the market in only a 2” x 2” square housing. Not only are they the brightest, they are the most efficient with the s1100 drawing only 0.75 amps. Due to their advanced electronic drivers the units have lifecycle of 50,000+ hours and a variable 9 - 50 Volt DC input. The Solstice Solo’s main feature is the 4 sided channel design that allows you to interlink it on all four sides with another Solstice Solo Pod, or other various available mounting hardware for flat, tube or even helmet mount, making it the only modular light with the ability to make any shape or length. Spot, Euro and Flood beam lenses can be mixed in your custom configuration.
Rugged die-cast aluminium housing provides optimum durability and heat dissipation. The Solstice Solo series features an IP68 ingress protection rated housing making them impenetrable to dust and submersible under water up to 3 meters. The unbreakable Polycarbonate lenses are housed by a 6061 aluminum face plate which doubles as a radiant heat sink to melt away snow and ice in frigid conditions. The Solstice Solo series has been subjected to a 14Grms vibration test to ensure their performance in high impact conditions. Built to last, this unit features a solid warranty.
also see https://www.visionxusa.com/LED-Solstice-S1100/c1_48_88/index.html for more information
[email protected]
