XR650L piston carb etc.
reinton
Ariel (all models)
Hi fellow doggies,
  my XR 650L has about 75000 klicks on it and is using oil.
  As I'm going to change 2nd and 5th gear I will fix the oil issue as well.
  Which piston will you guys recommend. Though I,ll like a bit more power it must not be at the cost of reliability.
  Do you get after market gasket sets, valve stem seals, timing chain/ sliders etc? Is Honda the only option?
  Now to carb issues:
  Just after I bought the bike  I fitted a Keihin FCR41 pumper carb and a FMFQ4 slip on silencer.
  About 5000 kilos later a piece of the slide broke of and went through the engine. Replaced the slide. Almost the price of the carb! That slide also broke a piece of. I put the standard carb back.
  Now what caused that?
  I will appreciate  advice from you all.
  Vendors that can help with spares please let me know.
