- Jul 27, 2010
- 5,499
- 670
- Blouberg, Cape Town
- KTM 890 Adventure R
The Adventure LED Spotlights are sturdy 1000 Lumen LED spotlights to work as DRLs or improving night vision. Shaft beams probe into the night to light up the road ahead, while an auxiliary circle of secondary light is available for seeing the road closer to you.
Sturdy construction, with mounts integrated into the body makes them ideal for adventure riding and DS bikes. A stainless steel mount connects them to the bike.
Specifications:
•9 - 36 Volt DC
•1x 10 watt CREE LED
•IP68 – dust and waterproof
•Focused Spot Beam with long throw
•1000 Lumen
•Stainless steel bracket
•Powder coated die cast aluminum body
Dimensions
•Diameter = 65mm
•Total Height = 86mm
•Thickness = 80mm
•Weight = 300 grams
Installation:
No switch needed. Just connect to high beam wires in the headlight enclosure. They can be installed using a handlebar switch, and relay.
The Adventure LED spots are slightly bigger and heavier, but provides a probing beam into the darkness. They can be used as DRLs in conjunction with normal lights to provide a recognizable triangle.
Price: R420 per light
Specifications:
•9 - 36 Volt DC
•1000 Lumen
Dimensions
•Diameter = 65mm
•Thickness = 80mm
•Weight = 300 grams
Installation:
