Oil behind Clutch Slave housing - now leaking/dripping
KOLI
Western Cape
KTM 990 Adventure
Hi
I have noticed oil behind my clutch slave housing on my previous clutch jet cleaning. But yesterday I have noticed it was now so bad it started to leak out from the slave housing.
It does not seem to be from the Clutch master cylinder but rather engine oil.
It seems there is a seal where the clutch rod enters the engine casing, if this is the seal can this be easily replaced? The manual says something about a special tool....Or is this easy enough to replace. Do I need to remove the clutch basket first to get the rod out of the way, or how did others managed to get the seal out?
Also seal only available from KTM?
Does anyone have the size for the seal?
Any advice would be appreciated,
Thanks
